[GRASS-dev] [GRASS GIS] #1554: wxGUI Cartographic Composer: preview broken on Windows
SWAPAN GHOSH
swap.ghsh at gmail.com
Wed May 1 23:29:42 PDT 2013
Hi all,
It needs to change the code for "EpsImagePlugin.py" in the Python PIL
packages as below-
command = ["gswin32c",
"-q", # quite mode
"-g%dx%d" % size, # set output geometry (pixels)
"-dNOPAUSE -dSAFER", # don't pause between pages, safe
mode
"-sDEVICE=ppmraw", # ppm driver
"-sOutputFile=%s" % file # output file
Then It will work in windows.
Regards,
Swapan
> Reporter: martinl | Owner:
> grass-dev@…
> Type: defect | Status: new
> Priority: critical | Milestone: 6.4.3
> Component: wxGUI | Version:
> unspecified
> Keywords: cartographic composer, psmap, wingrass | Platform:
> MSWindows XP
> Cpu: Unspecified |
> Comment(by annakrat):
> Replying to [comment:40 martinl]:
> > Replying to [comment:38 annakrat]:
> > > > Quick test: `ps2pdf` works from cmd, cartographic composer fails
> with `Cannot open this file: _.at`
> > > and it complains about missing gssetgs.bat (in terminal)
> > added to `gs` package (9.07-3)
> still not working, some 'unrecoverable error' shows in the terminal
> Ticket URL: <https://trac.osgeo.org/grass/ticket/1554#comment:41>
> GRASS GIS <http://grass.osgeo.org>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130502/b57c5ae8/attachment.html>
