[GRASS-dev] wxGUI toolboxes
Sören Gebbert soerengebbert at googlemail.com
Thu May 2 01:11:42 PDT 2013
Hi Anna,
2013/5/2 Anna Kratochvílová <kratochanna at gmail.com>
> On Thu, May 2, 2013 at 9:52 AM, Sören Gebbert
> <soerengebbert at googlemail.com> wrote:
> > Hi,
> > this is really great, many thanks! I am looking forward to add a temporal
> > modules menu layout.
> I was about to suggest adding temporal framework to the toolboxes so
> that it can be optionally added to menu. Will you try it? The needed
> information should be in the programming manual. Or I can create the
> toolbox and you can improve it later. The main work beside creating
> the structure is to add menu labels.
That is nice, i would like to improve it later. :)
Best regards
Soeren
> Anna
> > Best regards
> > Soeren
> > 2013/4/30 Vaclav Petras <wenzeslaus at gmail.com>
> >> Hi all,
> >> first version of toolboxes for wxGUI is released (for GRASS GIS 7) and
> >> is available in trunk. The main purpose of toolboxes is the wxGUI menu
> >> customization. The current implementation of toolboxes does not
> >> influence the set of installed or available modules. The toolboxes are
> >> the possibility to create different highly specialized menu layouts.
> >> Users, which are able to edit XML, can now create toolboxes which
> >> contain modules from GRASS distribution, existing toolboxes (from the
> >> distribution) and modules from addons or their own modules. These
> >> toolboxes or set of toolboxes (in the toolboxes file) can be copied
> >> and shared, and users, which are able to copy the file into the
> >> .grass7 directory, can use them. Note that distribution of toolboxes
> >> is now not connected to the distribution of modules itself. GUI
> >> front-end is not available.
> >> The main menu (main menubar) is treated separately in the separate
> >> file with slightly different structure but its very similar to toolbox
> >> and it follows the same concepts.
> >> Note that you need to create your custom toolboxes.xml file or
> >> main_menu.xml file into your $HOME/toolboxes directory to see
> >> toolboxes in action.
> >> For the detailed description please see Programmer's Manual [1] and
> >> for future consideration and development issues see Trac [2].
> >> Anna and Vaclav
> >> [1] http://grass.osgeo.org/programming7/wxguitoolboxes.html
> >> [2] http://trac.osgeo.org/grass/wiki/wxGUIDevelopment/Toolboxes
> >> (links will work soon)
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130502/7e797d64/attachment-0001.html>
