[GRASS-dev] [GRASS GIS] #1036: empty monitor in i.pr.classify
trac at osgeo.org
Thu May 2 01:25:58 PDT 2013
Reporter: arocha1980 | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Addons | Version: 6.4.0 RCs
Keywords: i.pr, i.pr.classify, d.mon | Platform: Linux
Cpu: Unspecified |
Description changed by hamish:
Old description:
> While using i.pr.classify i found 2 bugs.
> 1- from GUI it's not possible to run i.pr.classify due to the fact that
> it needs to have d.mon x0
> 2 (and this one is CRITICAL) First I do d.mon x0 and an empty monitor
> appears
> Then, when I do:
> i.pr.training map=liss.1 at Portugal_9 vis_map=liss342 at Portugal_9
> training=outfile rows=3 cols=3 class=1
> No image is displayed only 3 black panels and some instructions in lower-
> right panel. Instead of displaying vis_map. And, if I select randomly
> some points in the black space and save I get an empty file.
New description:
1- from GUI it's not possible to run i.pr.classify due to the fact that it
appears
Then, when I do:
right panel. Instead of displaying vis_map. And, if I select randomly some
Ticket URL: <https://trac.osgeo.org/grass/ticket/1036#comment:4>
