[GRASS-dev] [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS installer distribution
GRASS GIS trac at osgeo.org
Thu May 2 03:51:44 PDT 2013
 Reporter:  ddalimonte                 |       Owner:  hamish
     Type:  defect                     |      Status:  new
 Priority:  major                      |   Milestone:  6.4.3
Component:  Projections/Datums         |     Version:  svn-releasebranch64
 Keywords:  r.in.wms, wingrass, cs2cs  |    Platform:  MSWindows XP
      Cpu:  All                        |
Changes (by hamish):
  * milestone:  6.4.2 => 6.4.3
Comment:
 suggestion: for 6.4.4 let's consider packaging r.in.wms2.py in with
 gui/scripts/, and have it as the menu item from the wxGUI. the shell
 version can still be there from the command line, but I don't see it
 getting much more than maintenance fixes at this point.
 I know the wheel is already invented a number of times, but I'd also
 suggest to try and make more use of OWSLib, to outsource the OGC protocol
 stuff to an existing library/team.
    http://geopython.github.io/OWSLib/
 todo: test current state of r.in.wms(.sh) in grass6 after the script-
 called-from-a-script patches have been applied (#1727).
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:45>
