[GRASS-dev] [GRASS GIS] #1554: wxGUI Cartographic Composer: preview broken on Windows
GRASS GIS trac at osgeo.org
Thu May 2 04:57:03 PDT 2013
 Reporter:  martinl                                 |       Owner:  grass-dev@…
     Type:  defect                                  |      Status:  new
 Priority:  critical                                |   Milestone:  6.4.3
Component:  wxGUI                                   |     Version:  unspecified
 Keywords:  cartographic composer, psmap, wingrass  |    Platform:  MSWindows XP
      Cpu:  Unspecified                             |
Comment(by hamish):
 > Replying to [comment:42 annakrat]:
 > > Hamish, please test as soon as possible r56077 (in grass6.5) so
 > > I can backport it if working. PDF is created now directly with gs
 > > instead of ps2pdf. I used the command from  comment:34.
 thanks, fingers crossed :) too late here tonight so I'll test in the
 morning once Martin's build is complete.
 it worked from the C:\> prompt, so with luck & no typos..
 > Since we don't have much time before release, I committed it directly to
 6.4,
 > it cannot break anything.
 Once I thought the same; you'll see a 6.3.0.1 version in the svn tags
 because I was wrong about it. :)
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1554#comment:44>
