[GRASS-dev] [GRASS GIS] #1957: v.in.ascii (points.c) does not import some numbers in attached example
GRASS GIS trac at osgeo.org
Thu May 2 22:15:27 PDT 2013
 Reporter:  ychemin     |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.5.0
Component:  Vector      |     Version:  svn-trunk
 Keywords:  v.in.ascii  |    Platform:  Linux
      Cpu:  x86-64      |
Comment(by hamish):
 max dbf columns somewhere 255-1028+
   http://compgroups.net/comp.lang.clipper/maximum-fields-per-record-
 dbf/888510
 for sqlite: "`The default setting for SQLITE_MAX_COLUMN is 2000. You can
 change it at compile time to values as large as 32767.`"
   http://www.sqlite.org/limits.html
 PgSQL, "250 - 1600 depending on column types",
   http://www.postgresql.org/about/
 MySQL, "There is a hard limit of 4096 columns per table, but the effective
 maximum may be less for a given table."
   http://dev.mysql.com/doc/refman/4.1/en/column-count-limit.html
 how many met stations? if less than the number of time records maybe
 consider to invert the array and organize data by time instead of
 position? or split up into multiple files by e.g. year?
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1957#comment:2>
