[GRASS-dev] [GRASS GIS] #1957: v.in.ascii (points.c) does not import some numbers in attached example
GRASS GIS trac at osgeo.org
Thu May 2 22:23:37 PDT 2013
 Reporter:  ychemin     |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.5.0
Component:  Vector      |     Version:  svn-trunk
 Keywords:  v.in.ascii  |    Platform:  Linux
      Cpu:  x86-64      |
Comment(by hamish):
 probably best to write a script to create one vector map per row, with
 columns 3-inf rotated into a single column; and the timestamps in a second
 column, matching the data by row number.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1957#comment:4>
