[GRASS-dev] [GRASS GIS] #1747: v.rast.stats on dbf shapefile not enough precision even with DOUBLE PRECISION
trac at osgeo.org
Fri May 3 08:50:19 PDT 2013
PRECISION
Reporter: vesnikos | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: v.rast.stats | Platform: Linux
Cpu: x86-32 |
Comment(by elcol):
Replying to [comment:5 hamish]:
> Replying to [comment:4 elcol]:
> > I can confirm this bug. I also only get 2 decimals instead of double
precision
> > for column attributes, also when using v.db.select. I am using GRASS
6.4.2
> is the database backend dbf?
> if so, can you look at it with a utility like 'dbview' or
{Open|Libre}Office Calc and inspect the data values in it? Perhaps the raw
data is that way and v.db.* is just rounding off the .000000000s
> Hamish
I'm using the default dbf backend. I've just checked the .dbf file with
LibreOffice, and all data has only 2 decimals in the actual file too.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1747#comment:6>
