[GRASS-dev] [GRASS GIS] #560: WinGRASS not deleting temp ppm files from map display
GRASS GIS trac at osgeo.org
Fri May 3 22:34:14 PDT 2013
 Reporter:  isaacullah                  |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  critical                    |   Milestone:  6.4.3
Component:  Display                     |     Version:  6.4.0 RCs
 Keywords:  v.digit ppm temp, wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32                      |
Comment(by hamish):
 fwiw the tcl/tk gui in wingrass saves its .ppm files to $MAPSET/.tmp, and
 succeeds in cleaning them up. It uses g.pnmcomp too, so I guess that
 g.pnmcomp exiting without explicitly closing the image files is not the
 reason for failure-to-delete?
 Hamish
 (argh trac is logging me off every 10 minutes today..)
Ticket URL: <https://trac.osgeo.org/grass/ticket/560#comment:18>
