[GRASS-dev] [GRASS GIS] #1849: Cannot create a new GRASS Location using a custom proj4 string
trac at osgeo.org
Sat May 4 02:15:19 PDT 2013
Reporter: voncasec | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Projections/Datums | Version: unspecified
Keywords: proj4, location wizard, wxgui | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
Added the -t flag to g.proj in devbr6 for testing, now for the utm 10
example above I still get the python error "`object of type 'int' has no
len()`" from comment:2, but at least the proj4 terms are populated and the
location creates itself ok. I notice that after selecting the default
3-term datum transform that +towgs84=0,0,0,0,0,0,0. No problem since it's
the same as 0,0,0, but perhaps a sign of trouble elsewhere. -- it is,
trying again with the Florida transform grid ends up with the same result,
+towgs84=0,0,0,0,0,0,0 and no grid file selected in the PROJ_INFO file.
different than in comment:2 (which was run on linux), on wingrass 6.5svn I
get the "`define one of flags -p,-g,-j or -w`" error box for nad83 too.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:5>
