[GRASS-dev] [GRASS GIS] #1961: wxNVIZ: error if no raster map selected
trac at osgeo.org
Sat May 4 11:46:18 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: wxnviz | Platform: All
Cpu: x86-64 |
Comment(by annakrat):
Replying to [ticket:1961 hamish]:
> Hi,
> testing wxNVIZ in latest 6.5svn, I get an error and 100% CPU use if I
select '3D view' in the map display window with just a vector map
selected. (also tried with a 3D vector map, same thing) happens both on my
linux and Wingrass-VM. It's recoverable once you switch back to '2D view'
mode.
> one possible solution is in the case of no raster tell nviz to create a
new constant surface at z=0 with 50% transparency. (or at least that's the
trick with tcl/tk nviz + no raster to drape things on)
It seems that this is already done. Try r56122 which should fix the
traceback.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1961#comment:1>
