[GRASS-dev] [GRASS GIS] #1891: wingrass: background dosbox from regular wxgui startup
GRASS GIS trac at osgeo.org
Sat May 4 16:55:32 PDT 2013
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  6.4.3
Component:  Default   |     Version:  svn-releasebranch64
 Keywords:  wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-64    |
Comment(by hamish):
 Replying to [comment:38 hamish]:
 > Helmut wrote:
 > > [can't test standalone cause of a nasty dll hell - aka interfering
 installed
 > > python vs. bundled python]
 > at install time or run time? You should be able to change GRASS_PYTHON
 to the
 > exact c:\path\python.exe you want to use in %GISBASE%/etc/env.bat.
 ... and since %GISBASE%/etc/env.bat gets replaced at reinstall, you can
 also create a personal env.bat in your %APPDATA%/GRASS6/ dir, which is
 called after the system version, that way your local environment changes
 survive reinstall.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1891#comment:40>
