[GRASS-dev] [GRASS GIS] #1959: wingrass wx carto composer: Image causes traceback
trac at osgeo.org
Sun May 5 09:32:40 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: cartographic composer, wingrass | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by annakrat):
Replying to [comment:2 annakrat]:
> Please try r56120.
OK, this works. However we have different problem now. Apart from missing
refresh of the image in the dialog (hopefully fixed in r56133), I get
'IOError: error when accessing file' when I select eps file. See this
[http://mail.python.org/pipermail/image-sig/2004-April/002722.html
question]. This is problem for the eps files like grasslogo.eps or
compass_in/exterior.eps because they don't have 'showpage' command inside
unlike the newer eps north arrows. Adding this command would probably
solve the problem, but I am not sure if it safe. EPS
[http://partners.adobe.com/public/developer/en/ps/5002.EPSF_Spec.pdf
specification] allows it.
Another error when drawing eps in draft mode (r56134).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1959#comment:3>
