[GRASS-dev] [GRASS GIS] #1747: v.rast.stats on dbf shapefile not enough precision even with DOUBLE PRECISION
trac at osgeo.org
Sun May 5 13:54:13 PDT 2013
PRECISION
Reporter: vesnikos | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: v.rast.stats | Platform: Linux
Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:8 ElcoL]:
> Its slope data that i got using r.slope.aspect on a DEM. Map query
reports
> up to 10 decimals, so the dataset looks normal.
Which method did you use to convert the raster result to a vector map?
i.e. exact command line arguments used with v.rast.stats? Did you use the
-e flag? what was the vector polygon map like? does 'r.univar -t' look
normal on the query map?
Is the normal looking map query of the DEM or the result of
r.slope.aspect?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1747#comment:9>
