[GRASS-dev] [GRASS GIS] #1891: wingrass: background dosbox from regular wxgui startup
GRASS GIS trac at osgeo.org
Mon May 6 03:39:24 PDT 2013
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  6.4.3
Component:  Default   |     Version:  svn-releasebranch64
 Keywords:  wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-64    |
Comment(by hamish):
 Replying to [comment:48 neteler]:
 > I have attached screenshots. The problem is in Init.bat
  if "%PYTHONPATH%" == "" (
         set PYTHONPATH=%GISBASE%\etc\python
  ) else (
         set PYTHONPATH=%PYTHONPATH%;%GISBASE%\etc\python
 I tried on Windows7 (instead of XP as earlier) and I could reproduce the
 same error there. The English version of the error message is "`/GRASS was
 unexpected at this time.`"
 the method seems pretty much the same as the GRASS_WISH and GRASS_GUI ones
 nearby, so I'm not sure what would be wrong with it, or why it matters in
 7,8 but not XP, but it seems to be treating the forward-slash dirseps in
 GISBASE as a switch(?).
 try r56137,8.
 an alternative solution might be to try to pass the 8.3 shortname version
 of %GISBASE%. (`echo %~sI`)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1891#comment:49>
