[GRASS-dev] [GRASS GIS] #1966: filesystem cruft from wingrass installer
trac at osgeo.org
Mon May 6 14:08:31 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: trivial | Milestone: 7.0.0
Component: Packaging | Version: svn-trunk
Keywords: wingrass | Platform: MSWindows XP
Cpu: All |
Comment(by hamish):
the wingrass installer isn't using 'make install', it simply does a
recursive copy of src/demolocation/ from the svn checkout directory:
;Define the source path of the demolocation files
!define DEMOLOCATION_PATH
"c:\OSGeo4W at OSGEO4W_DIR_POSTFIX@\usr\src\grass_trunk\demolocation"
;Install demolocation into the GIS_DATABASE directory
SetOutPath "$GIS_DATABASE\demolocation"
File /r ${DEMOLOCATION_PATH}\*.*
so as long as that is the case, probably an explicit delete like is done
for .svn/ there is needed too.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1966#comment:2>
