[GRASS-dev] [GRASS GIS] #1968: traceback error in wxgui goutput.py on save command output
GRASS GIS trac at osgeo.org
Tue May 7 17:10:26 PDT 2013
 Reporter:  hamish  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  minor   |   Milestone:  6.4.3
Component:  wxGUI   |     Version:  svn-develbranch6
 Keywords:          |    Platform:  All
      Cpu:  All     |
 I get a traceback message in the terminal when I click to save the command
 window output from a module GUI. Both on linux and MS Windows, 6.4.3svn
 and devbr6 (but not in trunk).
  * start a grass command line session
  * bring up a module GUI: g.version --ui
  * select the -b build info flag
  * click run (note scrollbar doesn't cover full ./configure line unless
 you highlight drag the text)
  * Output window -> Save, pick filename, ok
 then,
   File "/home/hamish/src/grass/svn/relbr_6_4/dist.x86_64-unknown-linux-
 gnu/etc/wxpython/gui_core/goutput.py", line 679, in OnOutputSave
     self.parent.SetStatusText(_("Command output saved into '%s'") % path)
 AttributeError: 'CmdPanel' object has no attribute 'SetStatusText'
 but the file is saved ok.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1968>
