[GRASS-dev] [GRASS GIS] #1970: cairo config on Mac can't find pkg-config
trac at osgeo.org
Wed May 8 15:07:15 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Packaging | Version: svn-trunk
Keywords: configure, cairo | Platform: MacOSX
Cpu: All |
on Mac OSX the ./configure script comes up with a few errors, and possibly
doesn't enable all rendering options that could be enabled because it
tries to use the pkg-config program.
an example from Michael:
./configure [...] --with-cairo --with-cairo-includes="/Library/Frameworks\
/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework\
/unix/include" --with-cairo-libs=/Library/Frameworks/cairo.framework\
/unix/lib --with-cairo-ldflags="-lcairo" [...]
checking whether to use Cairo... yes
./configure: line 11623: pkg-config: command not found
./configure: line 11630: pkg-config: command not found
checking for location of cairo includes...
/Library/Frameworks/cairo.framework/unix/include/cairo
checking for cairo.h... yes
./configure: line 11700: pkg-config: command not found
checking for location of cairo library...
/Library/Frameworks/cairo.framework/unix/lib
config.log is available upon request, but I think the above says it all.
the relevant part of configure.in is:
# Enable Cairo display driver option
LOC_CHECK_USE(cairo,Cairo,USE_CAIRO)
CAIROINC=
CAIROLIB=
if test -n "$USE_CAIRO"; then
cairo="cairo"
pkgs="cairo-ft cairo-fc cairo-pdf cairo-ps cairo-svg fontconfig"
if test -n "$USE_X11"; then
pkgs="$pkgs cairo-xlib cairo-xlib-xrender"
fi
for pkg in $pkgs ; do
if pkg-config --exists $pkg ; then
cairo="$cairo $pkg"
fi
done
# With Cairo includes directory
#FIXME: somehow quote dirs with spaces in $cairo ?
CAIROINC=`pkg-config --cflags $cairo`
LOC_CHECK_INC_PATH(cairo,cairo,CAIROINC)
LOC_CHECK_INCLUDES(cairo.h,Cairo,$CAIROINC)
# With Cairo library directory
CAIROLIB=`pkg-config --libs $cairo`
LOC_CHECK_LIB_PATH(cairo,cairo,CAIROLIB)
LOC_CHECK_LDFLAGS(cairo,cairo,CAIROLIB)
LOC_CHECK_FUNC(cairo_create,,,,,$CAIROLIB,[:])
LOC_CHECK_FUNC(cairo_xlib_surface_create_with_xrender_format,,,,,$CAIROLIB,
[CAIRO_HAS_XRENDER=1],[CAIRO_HAS_XRENDER=])
AC_SUBST(CAIRO_HAS_XRENDER)
LOC_CHECK_FUNC(cairo_xlib_surface_get_xrender_format,,,,,$CAIROLIB,
[CAIRO_HAS_XRENDER_SURFACE=1],[CAIRO_HAS_XRENDER_SURFACE=])
AC_SUBST(CAIRO_HAS_XRENDER_SURFACE)
CAIROLIB="$CAIROLIB $CAIROLDFLAGS"
fi # $USE_CAIRO
i.e. it assumes that pkg-config will always be there.
Platform.make ends up with:
#cairo
CAIROINC =
-I/Library/Frameworks/cairo.framework/unix/include/cairo
CAIROLIB =
-L/Library/Frameworks/cairo.framework/unix/lib -lcairo
USE_CAIRO = 1
CAIRO_HAS_XRENDER =
CAIRO_HAS_XRENDER_SURFACE =
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1970>
