[GRASS-dev] [GRASS GIS] #1849: Cannot create a new GRASS Location using a custom proj4 string
trac at osgeo.org
Fri May 10 05:46:28 PDT 2013
Reporter: voncasec | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Projections/Datums | Version: unspecified
Keywords: proj4, location wizard, wxgui | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:11 hamish]:
> setup by custom proj terms hopefully fixed & working ok in devbr6
> as of r56176 (please test with your local!), similar fixes for
> epsg remain todo.
epsg, custom proj terms still not right in wingrass+proj 4.8.0, but
looking ok on linux+proj 4.7.0.
It seems that the g.proj -t flag is needed with the 'g.proj -jw' calls to
get the datum transform on the summary page on wingrass+4.8.0, and the -t
flag is also needed in grass.create_location() (in core.py, at least for
epsg-mode) for the g.proj call there.
On wingrass 6.5 I tried 'g.proj -c epsg=27200 datumtrans=2
loc=test_without_t' right on the command line, and without using the -t
flag meant that the datum transform was not added to the resulting
PROJ_INFO file, instead the default proj4-heuristics option was used. With
the -t flag it respected the datumtrans= option.
> an existing bug in the custom proj terms (maybe elsewhere
> too) is if you select datum transform opt `0` from the
> list (i.e. don't specify transform opts) it picks the
> grass default one anyway.
this is a bug in g.proj ignoring `datumtrans=0`, or rather falling back to
the grass datum table default (this time, proj4 heuristics choose
differently). As I'm not entirely sure if that should be classed as a bug
or intended feature, I'll file it as another ticket. (seems ok in wingrass
6.5 + proj 4.8.0 but not linux 6.5 + proj 4.7.0)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:12>
