[GRASS-dev] r56095 broke vector libs
Martin Landa landa.martin at gmail.com
Mon May 13 03:36:09 PDT 2013
2013/5/13 Martin Landa <landa.martin at gmail.com>:
> 2013/5/13 Markus Metz <markus.metz.giswork at gmail.com>:
>> PLEASE test before committing changes. Or carefully read the current
>> code base. For future reference: vector topology is optional and reset
>> if no topology is required. That means you should NOT store
>> non-topological information in topological structures. Thanks.
> sorry for inconvenience, could you be more specific? What exactly
> broke the vector libs? Do you mean `version` struct? My attempt was to
> make the current data structures more understandable for the
> programmers.
OK, from your commit I can understand the issue. I hope that even with
my fault the result is valuable. Thanks for the fix.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
