[GRASS-dev] GRASS 7 crashes on startup on Mac
Anna Petrášová
kratochanna at gmail.com
Mon May 13 13:23:32 PDT 2013
Hi Michael,
On Mon, May 13, 2013 at 9:52 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
> I just compiled GRASS 7 Trunk.
> It crashes on startup with the following error:
this is related to the new toolboxes and menu customization. I don't know
what is wrong because it was tested successfully also on Windows. Could you
check what you have in directory toolboxes which should be in the same
folder as saved settings file? Also try make distclean or just make clean
in gui/wxpython and remove manually the gui files from distribution.
Anna
> GRASS 7.0.svn (nc_spm_08):~ > Traceback (most recent call last):
> File
> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py",
> line 140, in <module>
> sys.exit(main())
> File
> line 133, in main
> app = GMApp(workspaceFile)
> File
> line 45, in __init__
> wx.App.__init__(self, False)
> File
> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py",
> line 7981, in __init__
> self._BootstrapApp()
> File
> line 7555, in _BootstrapApp
> return _core_.PyApp__BootstrapApp(*args, **kwargs)
> File
> line 79, in OnInit
> workspace = self.workspaceFile)
> File
> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/frame.py",
> line 106, in __init__
> self._menuTreeBuilder = LayerManagerMenuData()
> File
> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/menudata.py",
> line 31, in __init__
> MenuTreeModelBuilder.__init__(self, filename)
> File
> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/core/menutree.py",
> line 61, in __init__
> xmlTree = etree.parse(filename)
> File
> "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/xml/etree/ElementTree.py",
> line 862, in parse
> tree.parse(source, parser)
> File
> line 587, in parse
> self._root = parser.close()
> File
> line 1254, in close
> self._parser.Parse("", 1) # end of data
> xml.parsers.expat.ExpatError: no element found: line 1, column 0
> No changes on my end since compiling it without a problem a week ago.
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
> www: http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130513/f2a37b8e/attachment-0001.html>
