[GRASS-dev] [GRASS GIS] #1974: buffer overflow in v.to.rast
GRASS GIS trac at osgeo.org
Tue May 14 01:47:18 PDT 2013
 Reporter:  mgeeves    |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  minor      |   Milestone:  6.4.3
Component:  Vector     |     Version:  6.4.2
 Keywords:  v.to.rast  |    Platform:  All
      Cpu:  All        |
Comment(by mgeeves):
 Hi Hamish,
 Sure - this is on Ubuntu 12.04 LTS, compiled from grass-6.4.2.tar.gz
 Reproducible here from two identical vectors:
 v.in.ascii fs=, input=-
 output=p1234567890123456789012345678901234567890123456789012
 0.1,51
 <CTRL+D>
 output=p12345678901234567890123456789012345678901234567890123
 0.1,51
 <CTRL+D>
 This one works
 v.to.rast input=p1234567890123456789012345678901234567890123456789012
 output=r_ok use=val
 This one fails
 v.to.rast input=p12345678901234567890123456789012345678901234567890123
 output=r_nok use=val
 *** buffer overflow detected ***: v.to.rast terminated
 ======= Backtrace: =========
 /lib/i386-linux-gnu/libc.so.6(__fortify_fail+0x45)[0xb763bdd5]
 /lib/i386-linux-gnu/libc.so.6(+0xfebaa)[0xb763abaa]
 /lib/i386-linux-gnu/libc.so.6(+0xfe208)[0xb763a208]
 /lib/i386-linux-gnu/libc.so.6(_IO_default_xsputn+0x91)[0xb75ad461]
 /lib/i386-linux-gnu/libc.so.6(_IO_vfprintf+0x53f0)[0xb7581be0]
 /lib/i386-linux-gnu/libc.so.6(__vsprintf_chk+0xc9)[0xb763a2d9]
 /lib/i386-linux-gnu/libc.so.6(__sprintf_chk+0x2f)[0xb763a1ef]
 v.to.rast(update_hist+0xbd)[0x804b7ad]
 v.to.rast(vect_to_rast+0x438)[0x804cd98]
 v.to.rast(main+0x302)[0x804a432]
 /lib/i386-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0xb75554d3]
 v.to.rast[0x804a4f9]
 <SNIP>
 Hopefully I've not done something daft elsewhere!
 Cheers,
 Mike
Ticket URL: <https://trac.osgeo.org/grass/ticket/1974#comment:2>
