[GRASS-dev] Copying Landsat MTL file(s) inside the cell_misc directory -- Python scripting
Nikos Alexandris
nik at nikosalexandris.net
Tue May 14 05:25:42 PDT 2013
Nikos Alexandris wrote:
> whose creation is the the import_landsat.py script featured in
> <http://grasswiki.osgeo.org/wiki/LANDSAT#Automated_data_import>?
This question is still valid :-). If my 2 proposed changes don't do something
seriously wrong, I would like to update the script in the wiki.
> I would like to expand it a bit in copying the respective metadata
> (*MTL.txt) files over to the (respective) "cell_misc" directory? I guess
> that using the "shutil" is the way to go, like:
1) I managed to integrate another small function (thanks to Luca D for off-
list support), actually a clone of one small function already found in the
script. It works like:
def copy_metafile(mapset):
# get the metafile
try:
metafile = glob.glob(mapset + '/*MTL.txt')[0]
print '\nThe identified metadata file is:\n %s\n' %
metafile.split('/')[1]
except IndexError:
return
# get environment variables & define path to "cell_misc"
gisenv=grass.gisenv()
CELL_MISC_DIR = gisenv['GISDBASE'] + '/' + gisenv['LOCATION_NAME'] + '/' +
gisenv['MAPSET'] + '/cell_misc'
print 'The identified metadata file will be copied at:\n %s\n' %
CELL_MISC_DIR
# copy the metadata file
shutil.copy (metafile, CELL_MISC_DIR)
I call this small function in the end of the "core" function
"import_tifs(mapset)" to copy the MTL file in the respective "cell_misc"
directory, i.e.:
2) The current script checks inside the MTL file for the string
'ACQUISITION_DATE' to get the date of acquisition. The code (lines 56-57) goes
like:
if 'ACQUISITION_DATE' in line:
result['date'] = line.strip().split('=')[1].strip()
Since newer MTL files contain the string 'DATE_ACQUIRED', another check is
required. The script certainly works by adding an extra if statement, like:
if 'DATE_ACQUIRED' in line:
Nevertheless, I want to merge the two "if" statements in one. So, my attempt
goes like
if 'DATE_ACQUIRED' or 'ACQUISITION_DATE' in line:
This is wrong. I have no idea, though, on why the former "simple" if
statements return a single line, while the latter if statement, which contains
the "or" operator, does return the complete MTL file content!
And, finally, the following works:
if 'DATE_ACQUIRED' in line or 'ACQUISITION_DATE' in line:
I know the following is a pure python question -- still, can someone shed some
light on why is there such a difference between
and
Thanks, Nikos
