[GRASS-dev] Overflow warning in r.mapcalc calculation
Rainer M Krug r.m.krug at gmail.com
Wed May 15 12:20:37 PDT 2013
On Wednesday, May 15, 2013, Glynn Clements wrote:
> Paulo van Breugel wrote:
> > I am having trouble with the following computation, which gives me an
> > overflow warning ("WARNING: Overflow occured in the calculation").
> > r.mapcalc "A = if(B==0,
> (round(C/0.0001)-1175699902)/(3007966667-1175699902) *100.0, 1)" --overwrite
> > whereby C is a map with values between 1 and 31000. It seems to be
> > related to the size of the numbers (no warning if I divide C by 0.001),
> > but I am not clear what limit I am hitting here or how to avoid this.
> > The warning does not stop the calculation, and the resulting map seems
> > to be correct. However, I rather avoid this warning, also because the
> > warning message causes problems when running in batch from within R.
> The round() function always returns an integer, regardless of its
> argument types. Integers are always 32-bit, so the result is limited
> to the range +/- 2147483647 (2^31-1).
True - but is there an equivalent function to round numbers outside the
integer range? Would be useful. Looking at the functions in r.mapcalc, I
can't think of a way of doing this?
Rainer
> Glynn Clements <glynn at gclements.plus.com <javascript:;>>
> grass-dev mailing list
> grass-dev at lists.osgeo.org <javascript:;>
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax (F):       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130515/2a1321a8/attachment.html>
