[GRASS-dev] Overflow warning in r.mapcalc calculation
Rainer M. Krug
Rainer at krugs.de
Thu May 16 00:38:32 PDT 2013
I just looked at the round function in xround.c, and it does not look to
complicated to modify round() to obtain have three more functions, aligned to the
R functions:
From the R help:
| ‘ceiling’ takes a single numeric argument ‘x’ and returns a
| numeric vector containing the smallest integers not less than the
| corresponding elements of ‘x’.
| ‘floor’ takes a single numeric argument ‘x’ and returns a numeric
| vector containing the largest integers not greater than the
| ‘trunc’ takes a single numeric argument ‘x’ and returns a numeric
| vector containing the integers formed by truncating the values in
| ‘x’ toward ‘0’.
In addition, an additional argument could be added to the round()
function to round to the number of specified decimal places, so that it
is equivalent to your suggestion, Paulo.
From the R help:
| ‘round’ rounds the values in its first argument to the specified
| number of decimal places (default 0).
Unfortunately I don't have the experience in C and absolutely no time at
the moment to get into it.
Cheers,
Rainer
Paulo van Breugel <p.vanbreugel at gmail.com> writes:
> I would second that, it certainly would be handy to be able to round
> numbers outside the integer range and in addition, rounding with a specific
> number of decimal places, like e.g., the function round() in R. Is there a
> specific reason the round() function results in an integer?
> Paulo
> On Wed, May 15, 2013 at 9:20 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
>> On Wednesday, May 15, 2013, Glynn Clements wrote:
>>> Paulo van Breugel wrote:
>>> > I am having trouble with the following computation, which gives me an
>>> > overflow warning ("WARNING: Overflow occured in the calculation").
>>> > r.mapcalc "A = if(B==0,
>>> (round(C/0.0001)-1175699902)/(3007966667-1175699902) *100.0, 1)" --overwrite
>>> > whereby C is a map with values between 1 and 31000. It seems to be
>>> > related to the size of the numbers (no warning if I divide C by 0.001),
>>> > but I am not clear what limit I am hitting here or how to avoid this.
>>> > The warning does not stop the calculation, and the resulting map seems
>>> > to be correct. However, I rather avoid this warning, also because the
>>> > warning message causes problems when running in batch from within R.
>>> The round() function always returns an integer, regardless of its
>>> argument types. Integers are always 32-bit, so the result is limited
>>> to the range +/- 2147483647 (2^31-1).
>> True - but is there an equivalent function to round numbers outside the
>> integer range? Would be useful. Looking at the functions in r.mapcalc, I
>> can't think of a way of doing this?
>> Rainer
>>> Glynn Clements <glynn at gclements.plus.com>
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel : +33 - (0)9 53 10 27 44
>> Cell: +33 - (0)6 85 62 59 98
>> Fax (F): +33 - (0)9 58 10 27 44
>> Fax (D): +49 - (0)3 21 21 25 22 44
>> email: Rainer at krugs.de
>> Skype: RMkrug
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
South Africa
Fax : +33 - (0)9 58 10 27 44
Skype: RMkrug
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130516/3a0e634f/attachment.pgp>
