[GRASS-dev] new location wizard wxgui problem in trunk
Anna Petrášová kratochanna at gmail.com
Thu May 16 00:57:06 PDT 2013
On Thu, May 16, 2013 at 9:03 AM, Yann Chemin <yann.chemin at gmail.com> wrote:
> ellipse.table.solar.system is there
there seems to something weird in the file, one word only in line could
cause these problems
Anna
> On 16 May 2013 12:31, Yann Chemin <yann.chemin at gmail.com> wrote:
> > As soon as I press the button...
> > On 16 May 2013 11:39, Hamish <hamish_b at yahoo.com> wrote:
> >> Yann wrote:
> >>> Using the new location button in the wxgui, this happens
> >> as soon as you press the button? or do you enter some values
> >> first? is 'ellipse.table.solar.system' being installed in
> >> $GISBASE/etc/proj/ ?
> >> (it works for me running out of src/dist.x86*/)
> >> Hamish
> >>> Traceback (most recent call last):
> >>>   File
> >>> "/usr/local/grass-7.0.svn/etc/gui/wxpython/gis_set.py",
> >>> line
> >>> 408, in OnWizard
> >>>     grassdatabase = self.tgisdbase.GetValue())
> >>>   File
> >>> "/usr/local/grass-7.0.svn/etc/gui/wxpython/location_wizard/wizard.py",
> >>> line 1804, in __init__
> >>>     self.__readData()
> >>>   File
> >>> line 2008, in __readData
> >>>     ellipse, rest = line.split(" ", 1)
> >>> ValueError: need more than 1 value to unpack
> >>>   File
> >>> line
> >>> 408, in OnWizard
> >>>   File
> >>>     self.__readData()
> >>>   File
> >>> Received EXIT message from GUI.
> >>> GRASS is not started. Bye.
> > Yann Chemin
> > Researcher at IWMI
> > Skype/FB: yann.chemin
> Yann Chemin
> Researcher at IWMI
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130516/8d47fa15/attachment.html>
