[GRASS-dev] [GRASS GIS] #1975: v.overlay.and gets "stuck"
GRASS GIS trac at osgeo.org
Thu May 16 02:39:16 PDT 2013
 Reporter:  kiarasky     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Vector       |     Version:  unspecified
 Keywords:  v.overlay    |    Platform:  Linux
      Cpu:  Unspecified  |
Description changed by martinl:
Old description:
> Hi all! It's Kiara. I am using a script to overlay two shapefiles,
> respectively line and polygon type. The overlay operation gets stuck at
> approximately 74%, and it happens in the script, by command line and also
> by using the grass toolbox in qgis. maybe the problem is the number of
> vertices?
> More info: (ALL_ROUTES_M1SO6 is the line map, prova_conc_grand_grass is a
> test polygon i'm using)
> GRASS 6.4.2 (Europe):~/Desktop/short-term/grass_CODE_NewData > v.overlay
> ainput=ALL_ROUTES_M1SO6 at PERMANENT atype=line alayer=1
> binput=prova_conc_grand_grass at PERMANENT btype=area blayer=1
> output=routes_overlapped_test2 operator=and
> Copying vector objects from vector map <ALL_ROUTES_M1SO6 at PERMANENT>...
>  100%
> Collecting input attributes...
> <prova_conc_grand_grass at PERMANENT>...
>  100%
> Building partial topology...
> Building topology for vector map <routes_overlapped_test2>...
> Registering primitives...
> 869 primitives registered
> 20203 vertices registered
> Number of nodes: 138
> Number of primitives: 869
> Number of points: 0
> Number of lines: 868
> Number of boundaries: 1
> Number of centroids: 0
> Number of areas: -
> Number of isles: -
> Breaking lines...
> ^C74%
> *** here I stopped the procedure, and after that I cannot open the map
> that has been created. My maximum wall time has been 20 minutes...is that
> normal?
> thanks a lot
> Kiara
New description:
 vertices?
  100%
  100%
 Number of points: 0
 Number of areas: -
 Number of isles: -
 Breaking lines...
 ^C74%
 normal?
 thanks a lot
 Kiara
Ticket URL: <http://trac.osgeo.org/grass/ticket/1975#comment:2>
