[GRASS-dev] [GRASS-user] RE : RE : Merge polygone with same attribut of a shapefile
Nikos Alexandris nik at nikosalexandris.net
Fri May 17 01:40:07 PDT 2013
Nikos Alexandris wrote:
> # get stats for cats in layer 2, that is for all different cats!
> v.rast.stats -c vector=polygons_tmp raster=RandomRaster column_prefix=rr2
> layer=2
> #...unfortunately, this last step in uploading stats in to layer 2, fails in
> G7 :-(
e.g.
v.rast.stats -c -e vector=polygons_tmp layer=2 raster=RandomRaster
colprefix=ee
Processing data (1 categories)...
Updating the database ...
DBMI-SQLite driver error:
Error in sqlite3_prepare():
no such column: ee_n
ERROR: Error while executing: 'UPDATE polygons_tmp_polygons_2 SET ee_n=196
       , ee_min=10 , ee_max=99 , ee_range=89 , ee_mean=53.8571428571429 ,
       ee_stddev=26.0770052744105 , ee_variance=680.010204081633 ,
       ee_cf_var=48.4188426845818 , ee_sum=10556 , ee_first_quartile=29 ,
       ee_median=54 , ee_third_quartile=76 , ee_percentile_90=90 WHERE
       cat=1'
WARNING: Failed to upload statistics to attribute table of vector map
         <polygons_tmp>.
I think it wrongly look in/for layer=1 ? The "Processing data (1
categories)..." is the suspect because:
# layer=2 contains...
v.db.select polygons_tmp layer=2 col=cat
cat
1
2
# and layer=1 contains
v.db.select polygons_tmp col=cat
cat
1
A bug?
Nikos
> # it works in G64! -- note different parameter naming: "colprefix="
> v.build polygons_tmp
> v.rast.stats -c vector=polygons_tmp layer=2 raster=RandomRaster
> colprefix=rr2
