[GRASS-dev] [GRASS-user] RE : RE : Merge polygone with same attribut of a shapefile
Nikos Alexandris
nik at nikosalexandris.net
Fri May 17 04:08:56 PDT 2013
Nikos wrote:
> >> # get stats for cats in layer 2, that is for all different cats!
> >> v.rast.stats -c vector=polygons_tmp raster=RandomRaster column_prefix=rr2
> >> layer=2
> >> #...unfortunately, this last step in uploading stats in to layer 2, fails
> >> in G7 :-(
Moritz wrote:
> v.db.addcolumn seems to lack the layer option here:
> https://trac.osgeo.org/grass/browser/grass/trunk/scripts/v.rast.stats/v.rast
> .stats.py#L194
> Try to add it in the script and see if that makes it work.
Indeed. Milles Mercis, N
ps- Care for a diff? Or already changed?
