[GRASS-dev] GRASS 7 crashes on startup on Mac
Anna Petrášová
kratochanna at gmail.com
Mon May 20 00:06:14 PDT 2013
Hi Michael,
On Tue, May 14, 2013 at 12:32 AM, Anna Petrášová <kratochanna at gmail.com>wrote:
> On Mon, May 13, 2013 at 11:51 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>> Perhaps I discovered the problem. Both the distribution version
>> (downloaded in the past hour) and (of course) the compiled version of
>> menudata.xml are empty.
> Yes, that's what I was thinking. Could you try to run this separately:
> python core/toolboxes.py > xml/menudata.xml
> which should be done during compilation but it seems to fail somehow. It
> should generate the xml menu file.
any update? I know you announced to be out of office but maybe you can try
it anyway?
Anna
>> Michael
>> ____________________
>> C. Michael Barton
>> Director, Center for Social Dynamics & Complexity
>> Professor of Anthropology, School of Human Evolution & Social Change
>> Arizona State University
>> voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
>> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> On May 13, 2013, at 2:18 PM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>> There might be a problem with compilation. Is there any error? Could
>> you check file menudata.xml in gui/wxpython/xml/ and the same file in
>> distribution? Is it there and what's inside?
>> On Mon, May 13, 2013 at 10:51 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>>> Anna,
>>> I deleted all the GUI code and did a new svn up and make distclean.
>>> Just finished compiling and have the same error on startup. The GUI
>>> crashes.
>>> Michael
>>> ______________________________
>>> C. Michael Barton
>>> Tempe, AZ 85287-2402
>>> USA
>>> fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
>>> www: http://csdc.asu.edu, http://shesc.asu.edu
>>> On May 13, 2013, at 1:23 PM, Anna Petrášová <kratochanna at gmail.com>
>>> wrote:
>>> Hi Michael,
>>> On Mon, May 13, 2013 at 9:52 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>>>> I just compiled GRASS 7 Trunk.
>>>> It crashes on startup with the following error:
>>> this is related to the new toolboxes and menu customization. I don't
>>> know what is wrong because it was tested successfully also on Windows.
>>> Could you check what you have in directory toolboxes which should be in the
>>> same folder as saved settings file? Also try make distclean or just make
>>> clean in gui/wxpython and remove manually the gui files from distribution.
>>> Anna
>>>> GRASS 7.0.svn (nc_spm_08):~ > Traceback (most recent call last):
>>>> File
>>>> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py",
>>>> line 140, in <module>
>>>> sys.exit(main())
>>>> File
>>>> line 133, in main
>>>> app = GMApp(workspaceFile)
>>>> File
>>>> line 45, in __init__
>>>> wx.App.__init__(self, False)
>>>> File
>>>> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py",
>>>> line 7981, in __init__
>>>> self._BootstrapApp()
>>>> File
>>>> line 7555, in _BootstrapApp
>>>> return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>>> File
>>>> line 79, in OnInit
>>>> workspace = self.workspaceFile)
>>>> File
>>>> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/frame.py",
>>>> line 106, in __init__
>>>> self._menuTreeBuilder = LayerManagerMenuData()
>>>> File
>>>> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/menudata.py",
>>>> line 31, in __init__
>>>> MenuTreeModelBuilder.__init__(self, filename)
>>>> File
>>>> "/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/core/menutree.py",
>>>> line 61, in __init__
>>>> xmlTree = etree.parse(filename)
>>>> File
>>>> "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/xml/etree/ElementTree.py",
>>>> line 862, in parse
>>>> tree.parse(source, parser)
>>>> File
>>>> line 587, in parse
>>>> self._root = parser.close()
>>>> File
>>>> line 1254, in close
>>>> self._parser.Parse("", 1) # end of data
>>>> xml.parsers.expat.ExpatError: no element found: line 1, column 0
>>>> No changes on my end since compiling it without a problem a week ago.
>>>> Michael
>>>> C. Michael Barton
>>>> USA
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130520/a8e227ac/attachment-0001.html>
