[GRASS-dev] [GRASS GIS] #1976: r.mapcalc: Allow rounding of floating numbers
Rainer M. Krug
Rainer at krugs.de
Mon May 20 02:29:28 PDT 2013
"GRASS GIS" <trac at osgeo.org> writes:
> Reporter: pvanbosgeo | Owner: grass-dev@…
> Type: enhancement | Status: new
> Priority: normal | Milestone: 7.0.0
> Component: Raster | Version: unspecified
> Keywords: r.mapcalc | Platform: Unspecified
> Cpu: Unspecified |
> Comment(by mmetz):
> Replying to [ticket:1976 pvanbosgeo]:
> > The round() function in r.mapcalc always returns an integer, regardless
> of its argument types. Integers are always 32-bit, so the result is
> limited to the range +/- 2147483647 (2^31-1).
> > Suggestion: extend the function to allow to round numbers outside the
> integer range, and to round with a specific number of decimal places, like
> e.g., the function round() in R.
> Try trunk r56313.
> The output type of round() is now the same like the input type. Rounding
> to a given number of decimal places is supported with round(x, y) with y =
> number of decimal places. The new function round(x, y) supports a negative
> number of decimal places: for example, round(119, -1) results in 120, and
> round(119, -2) results in 100.
<#secure method=pgpmime mode=sign>
Great - sounds like a perfect solution to me.
Thanks,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
