[GRASS-dev] grass7 - mac osx- 64bit python
Anna Petrášová
kratochanna at gmail.com
Mon May 20 12:39:45 PDT 2013
On Mon, May 20, 2013 at 8:21 PM, epi <massimodisasha at gmail.com> wrote:
> thanks Anna!
> that's my bathymetry
> http://geofemengineering.it//data/nviz_mac_wx-29_cocoa.png
> I tried to changing resolution, use the slope map as color, light settings
> and other tools , everything was working properly :)
> few question :
> is it possible to "unlock" the layer manager and the map display so that
> when i move the layer manager the map window doesn't move with it ?
this behavior is only on Mac. Do also other multiple-window applications
behave this way (like gimp)?
> an important bug:
> i was looking for possible options in the preference settings to unlock
> the movement of mapdispaly when the layer manager is mived,
> but i had to force quit the gui every time i tried to do something in that
> panel
> when i click on "apply" in the console i have :
> Settings applied to current session but not saved
> then the gui is no more responsive and i forced it to quit
it is working for me. I have no idea and probably debug messages won't help
much. You could put some print statements in the code to localize more the
problem (starting at gui_core/preferences.py).
> .. will be nice to be able to set the transparence for the fringe panels
I see
> i'll try to export the verbose debug ant test again all the other widgets.
thanks again.
BTW, Michael Barton has had recently problem to start grass 7 wxGUI due to
new (a few weeks ago) toolboxes system (for menu customization). You
doesn't seem to have any problem, is that right?
Anna
> and generate more useful logs,
> thanks
> Massimo.
> Il giorno 20/mag/2013, alle ore 13:20, Anna Petrášová <
> kratochanna at gmail.com> ha scritto:
> Hi,
> On Mon, May 20, 2013 at 3:37 PM, epi <massimodisasha at gmail.com> wrote:
>> Hi,
>> is one week now that i'm testing a grass7 build, using wx cocoa (svn
>> version built from source)
>> i'm really happy to say that almost everything is working fine!
>> glad to hear that, I quickly tested wxGUI some time ago on wxPython 2.9
> on linux so the most apparent bugs should be fixed. Unfortunately most bugs
> you listed here are not reproducible on my ubuntu with 2.9 classic wxPython.
>> .. few debug reported here :
>> - profile tool :
>> -- the pen widget doesn't draw a line and no profile is plotted but ...
>> if i select the "measure tool" make a measurement and then
>> without quitting the measurement tool (boucle click on the canvas) i open
>> the profile tool .. then the profile is plotted correctly
> hm, I don't have this behavior, it's working properly. The only problem is
> that the dashed line does not disappear after rerendering.
> - add text layer :
>> -- doesn't change the font size
>> - map composer run but doesn't have a toolbar
>> again, both work for me
>> nothing is printed in the shell during the guy session, should i set some
>> env var to have more verbose
> this is normal, everything goes to gui command console, only when you
> switch to debug mode it goes to terminal
>> - nviz doesn't render the 3d canvas, but there is no crash :) , the
>> rendering-progress-bar load , this the log in the wx console
> please try again, I just updated the code for 2.9
>> Traceback (most recent call last):
>> File "/usr/local/grass-7.0.svn/etc/gui/wxpython/nviz/mapwi
>> ndow.py", line 366, in OnPaint
>> self.DoPaint()
>> ndow.py", line 406, in DoPaint
>> self.UpdateMap()
>> ndow.py", line 1166, in UpdateMap
>> self.SwapBuffers()
>> File "/usr/local/lib/wxPython-2.9.4.0/lib/python2.7/site-
>> packages/wx-2.9.4-osx_cocoa/wx/glcanvas.py", line 124, in
>> SwapBuffers
>> return _glcanvas.GLCanvas_SwapBuffers(*args, **kwargs)
>> wx._core
>> PyAssertionError
>> C++ assertion "context" failed at /BUILD/wxPython-
>> src-2.9.4.0/src/osx/cocoa/glcanvas.mm(289) in SwapBuffers():
>> should have current context
>> if there is something i can do to do more testing i will be happy to work
>> on it.
> I cannot do much about the bugs which I can't reproduce, especially when
> there is no error...
>> p.s.
>> with wx 2.9 we have great webkit support
>> @Anna have already tried to work on webkit in wx ?
> not yet, I probably missed something when I compiled wx 2.9, it was not
> working and then I didn't try again.
> Thanks and keep testing:)
> Anna
>> i will start to investigate this to see how to add a new tab to include
>> the Ipython notebook
>> if of interest, at this link there is a simple pyqt app that does
>> something similar :
>> https://github.com/damianavila/vIPer/blob/master/viper.py
>> Massimo.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130520/b831857d/attachment.html>
