[GRASS-dev] [GRASS GIS] #1976: r.mapcalc: Allow rounding of	floating numbers
    trac at osgeo.org
    Tue May 21 08:00:31 PDT 2013
 Reporter:  pvanbosgeo   |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Raster       |     Version:  unspecified
 Keywords:  r.mapcalc    |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by mmetz):
 Replying to [comment:4 glynn]:
 > Replying to [comment:2 mmetz]:
 > > The output type of round() is now the same like the input type.
 > This changes long-standing behaviour in a way which could break scripts.
 OK. Restoring the original behaviour for round(x) is easy. But it would be
 nice to have a round(x, y) function that preserves the data type of x in
 order to have a possibility to avoid integer overflow.
 > > Rounding to a given number of decimal places is supported with
 round(x, y)
 > From the mailing list discussion ...
 > Rounding to a given number of decimals is unnecessarily limiting. The
 algorithm for generalised rounding is essentially:
         roundTo(x, k) = round(x / k) * k.
 > Rounding to N decimal places is just a case of using k=1/10^N^. If you
 > allow k to be specified directly, then you can round to arbitrary
 > steps (e.g. k=5 would round to the nearest multiple of 5, etc).
 I was just looking at the function round() in R which rounds to decimal
 places. Generalised rounding makes more sense.
 > However: there's a slight problem with doing it that way: 0.1 isn't
 > exactly representable in binary, so e.g. x/0.1 isn't equal to x*10; it
 > would be more accurate to use:
         roundTo(x, k) = round(x * k) / k
 > where k is the reciprocal of the step, so k=10^N^ to round to N decimal
 > places (or k=2 to round to 1/2).
 > Unless someone has a better idea, I plan to change the round() function
 so that the second argument is the step value, and add an roundi() (round-
 inverse) function where the second argument is the reciprocal of the step
 value (to avoid the rounding error when using a step of 10^-N^).
 Sounds good to me.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1976#comment:5>
