[GRASS-dev] [GRASS GIS] #1976: r.mapcalc: Allow rounding of floating numbers
trac at osgeo.org
Wed May 22 12:58:30 PDT 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: unspecified
Keywords: r.mapcalc | Platform: Unspecified
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:4 glynn]:
> Unless someone has a better idea, I plan to change the round() function
so that the second argument is the step value,
Done in r56365. An optional third argument is the start value, so e.g.
round(x,1.0,0.5) will round to the nearest something-point-five value.
> and add an roundi() (round-inverse) function where the second argument
is the reciprocal of the step value (to avoid the rounding error when
using a step of 10^-N^).
I haven't bothered with this. If the step value can't be represented
exactly, then in the general case, neither can the rounded value. If it's
desired, it would be better to clone xround.c and modify the i_round()
function (swap the multiplication and division) than to try to get yet
another case into that file.
Rounding to a given number of decimal places (as opposed to rounding to a
multiple of 10^-N^) is something which really needs to be done during
conversion to a string. Attempting to round a floating-point value to a
given number of decimal places will inevitably add rounding errors which
may be visible if the value is subsequently converted to a string using
sufficient precision.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1976#comment:6>
