[GRASS-dev] GRASS 7: v.net.path and xml.etree.ElementTree ParseError
Anna Petrášová
kratochanna at gmail.com
Thu May 23 10:12:06 PDT 2013
On Thu, May 23, 2013 at 6:34 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> trying out v.net.path on yesterday's GRASS 7 OSGeo4W, the command runs
> through properly (correct result) but raises then an error:
> echo 1 1 2 | v.net.path KAnet_HbfHs alayer=1 nlayer=2 out=shortpath_dist
> --o
> WARNING: Il vettoriale <shortpath_dist> è già presente e sarà sovrascritto
> Creando il grafico...
> Registrando archi...
> Flattening the graph...
> Il grafico è stata creato
> Si sta ricreando la topologia per il vettore <shortpath_dist at KA_net>...
> Registrando primitive...
> 1 primitive registrate
> 140 vertici registrati
> Costruendo aree...
> 0 aree create
> 0 isole create
> Isole allegate...
> Centroidi allegati...
> Numero di nodi: 2
> Numero di primitive:1
> Numero di punti:0
> Numero di linee:1
> Numero di confini:0
> Numero di centroidi:0
> Numero di aree:0
> Numero di isole:0
> (Thu May 23 17:47:18 2013) Command finished (0 sec)
> Traceback (most recent call last):
> File "C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\gui\wxpython
> \core\gconsole.py", line 647, in OnCmdDone
> task = GUI(show=None).ParseCommand(event.cmd)
> \gui_core\forms.py", line 2188, in ParseCommand
> blackList = _blackList)
> File "C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\python\grass
> \script\task.py", line 487, in parse_interface
> tree = etree.fromstring(get_interface_description(name))
> File
> "C:\OSGeo4W\apps\Python27\lib\xml\etree\ElementTree.py",
> line 1300, in XML
> parser.feed(text)
> File
> line 1642, in feed
> self._raiseerror(v)
> File
> line 1506, in _raiseerror
> raise err
> ParseError
> syntax error: line 1, column 0
> Citing a related older wish:
> On Wed, Jan 25, 2012 at 3:58 AM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
> >> ParseError
> >> no element found: line 1, column 0
> > Would someone mind fixing the code to generate a more meaningful error
> > message when --interface-description fails (e.g. when the resulting
> > string is empty or consists solely of whitespace)?
> I wonder where the error comes from... happens on Linux as well. Perhaps
> the pipe | is causing it?
the problem is echo command because when you call 'echo
--interface-description' you get (surprisingly) '--interface-description'
(not error like any other bash command would raise). For other bash
commands (e.g. ls) you get (after ls output):
Unable to fetch interface description for command 'ls'.
Details: ls: unrecognized option '--interface-description'
Try `ls --help' for more information.
Please try r56388, there should be no error. But on Linux, pipe does not
seem to work as expected, anyway.
Anna
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130523/52ce30da/attachment.html>
