[GRASS-dev] rast_open_new() saturates after opening 127 temporary files
Tue May 28 13:04:48 PDT 2013
Yann Chemin wrote:
> Opening 127 temporary raster files is the limit of GRASS,
> How can I get above that limit?
You need to provide more information: version, OS, any error or debug
messages generated.
I don't have this problem with 7.0 on Linux.
But first, check that it isn't an OS issue. "ulimit -n" reports the
maximum number of open files (in 7.0, you need two per map). Also,
each completed raster needs a subdirectory within the cell_misc
directory, and some filesystems impose a limit on the number of
subdirectories (often much lower than the limit on the number of
files).
