[GRASS-dev] [GRASS GIS] #1982: v.rast.stats: running generates "Unable to fetch interface description for command" error
trac at osgeo.org
Tue May 28 16:58:52 PDT 2013
command" error
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: v.rast.stats | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by hamish):
perhaps g.parser is looking for "v.rast.stats" but only "v.rast.stats.py"
exists in the %PATH%, and it is missing the ".py" extension association?
(that only works in the DOSbox window, not the MSys one AFAIK, and GRASS7
doesn't have the .bat file wrappers in bin/)
what does "set" say at the GRASS cmd.exe prompt? is ";.PY" known?
do other python scripts like r3.in.xyz work there?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1982#comment:3>
