[GRASS-dev] [GRASS GIS] #560: WinGRASS not deleting temp ppm files from map display
trac at osgeo.org
Tue May 28 19:47:32 PDT 2013
Reporter: isaacullah | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Display | Version: 6.4.0 RCs
Keywords: v.digit ppm temp, wingrass | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by glynn):
Replying to [comment:22 hamish]:
> Ok, if $GISRC is custom you'd get tmp files in weird places. (render.py
could test if the getenv string started with "/tmp/grassX-" before using
that, otherwise use $TMPDIR?)
The init script uses TMPDIR or TEMP or tempfile.gettempdir(), and only
falls back to /tmp as the last resort.
> > Most uses of G_tempfile() are wrong
> what's the potential downside of that? why "wrong" instead of
"different"?
> i.e. is it theoretically wrong or practically wrong?
If /tmp (or $TMPDIR) is on a different filesystem to the mapset, it's
likely to be faster, e.g. /tmp is likely to be on a local disc even if the
mapset is on an NFS or CIFS share.
Ticket URL: <https://trac.osgeo.org/grass/ticket/560#comment:23>
