[GRASS-dev] [GRASS-SVN] r56452 - grass/trunk/scripts/g.extension
Pietro peter.zamb at gmail.com
Wed May 29 09:38:30 PDT 2013
On Tue, May 28, 2013 at 10:41 PM, Pietro <peter.zamb at gmail.com> wrote:
> Hi Martin,
> Sorry I didn't thought that an higher number of parameter were a problem.
> On Tue, May 28, 2013 at 1:57 PM, Martin Landa <landa.martin at gmail.com> wrote:
>> proxy="http:<value>,ftp:<value>"
> Personally I like your solution...
> Therefore if there are not objections I could implement it tomorrow.
I did, but actually I changed the syntax into:
proxy="http=<value>,ftp=<value>"
otherwise it will conflict with the proxy syntax:
http://DOMAIN\USERNAME:PASSWORD@SERVER:PORT/
