[GRASS-dev] G__getenv return different results from ctypes and from GRASS modules
Thu May 30 12:51:00 PDT 2013
Pietro wrote:
> Why the ctypes version return 'PERMANENT' instead of 'user1'?
The $GISRC file is read the first time that an environment lookup is
made. There is no way to force it to be re-read.
