[GRASS-dev] Subgroups in i.segment
Nikos Alexandris nik at nikosalexandris.net
Fri May 31 13:06:23 PDT 2013
Recently I did some tests (with Pietro Z) using "i.segment" on an RGB
orthophoto sample.  If am not wrong, the module works with "groups" only.
Driven by the discussion
"ticket #1984: i.pca should accept also group names as input (like
r.out.gdal)"
I wonder whether the module will support subgroups at some point as well.
Thank you, Nikos
