[GRASS-dev] Linearly stretch an image to match another image's Mean and StdDev
Nick Ves
vesnikos at gmail.com
Sun Nov 3 13:24:53 PST 2013
Hmmm, I need to check what is happening there.
Also nikos, take care, as I noticed i.histo.match [0] uses reclass to
produce the output map. Which makes it very sensitive in the input
data type.
N
[0] https://svn.osgeo.org/grass/grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
On Sun, Nov 3, 2013 at 6:00 PM, Nikos Alexandris
<nik at nikosalexandris.net> wrote:
> On Sunday 03 of November 2013 16:57:34 Markus Neteler wrote:
>> Hi Nikos,
>> it is not identical since i.histo.match uses a more advanced way. With
>> a simple linear scaling you can likely not gain much.
> Thank you for the clarification Markus.
> Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
