[GRASS-dev] /lib/gis/area_poly1.c: algorithm poorly described, new comments for consideration please
Vaclav Petras
wenzeslaus at gmail.com
Thu Nov 7 05:59:25 PST 2013
On Thu, Nov 7, 2013 at 12:47 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Richard,
> could you please download and edit the file
> http://svn.osgeo.org/grass/grass/trunk/lib/gis/area_poly1.c
> and send it back to me? Then I can update it as suggested.
> This would be great. Moreover, it would help if you put \verbatim before
the equations and \endverbatim after them, e.g.:
polygon's side) is defined by:
* \verbatim
* lat_2 - lat_1
* lat = lat_1 + (long - long_1) * ---------------
* long_2 - long_1
* \endverbatim
* where long_1 < long < long_2.
This ensures that the formatting will be preserved in generated programming
manual. Alternatively, it is possible to use also LaTeX syntax for
equations [1] but to be honest, I don't have a clear idea what's better.
Thanks for you explanation, Richard. It seems that it is really needed.
Vaclav
[1] http://www.stack.nl/~dimitri/doxygen/manual/formulas.html
thanks
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131107/acacdc5f/attachment.html>
