[GRASS-dev] [GRASS GIS] #2129: Vect_net_build_graph should check cost values
trac at osgeo.org
Thu Nov 7 07:21:29 PST 2013
Reporter: rblazek | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Default | Version: 6.4.3 RCs
Keywords: | Platform: All
Cpu: Unspecified |
Vect_net_build_graph check cost values read from database and call
G_fatal_error() if value is out of supported range:
1) values must be positive (except -1 used to exclude edge)
2) value * cost_multip sould be lower than dglInt32_t max value
Ticket URL: <http://trac.osgeo.org/grass/ticket/2129>
