[GRASS-dev] modifying the dblink it require to re-build the topology
Pietro Zambelli peter.zamb at gmail.com
Sat Nov 9 08:23:11 PST 2013
On Thursday 07 Nov 2013 09:25:21 you wrote:
> > I'm doing something wrong or is it a bug?
> I thought that maybe you forgot to use the type parameter, but I
> just tried in the NC dataset and can confirm your issue.
ok, the bug should be fixed in r58179, at the end it was much easier
than I thought.
Please test the v.category module, to be sure that I've not introduced
new bugs. :-)
> I know that it can be annoying to have to create new maps, but at
> the same time it is a failsafe that makes sure that even if you
> make a mistake in the call to v.category, you still keep your
> original data.
yes, it is particularly annoying, because the GRASS db driver is
pretty slow copying data from one table to another. Maybe we should
add a flag that skip to copy the attribute tables.
On the other hand, the tables are already there, we need only to link
the geometry features to the existing table.
Anyone against this new flag/option?
Best regards
Pietro
