[GRASS-dev] [GRASS GIS] #2128: t.vect.observe.strds vector output wirte values in the same layer
trac at osgeo.org
Sun Nov 10 03:41:51 PST 2013
Reporter: lucadelu | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Temporal | Version: svn-trunk
Keywords: t.vect.observe.strds output | Platform: Other Unix
Cpu: Unspecified |
Comment(by huhabla):
I would suggest to implement this functionality into a new module called
v.what.strds, since the output is a vector map and not a space time vector
dataset or time stamped tables of a vector map. The implementation would
be different from t.vect.observe.strds because the column names must be
generated from the time stamps and v.what.rast must be called to fill each
column.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2128#comment:1>
