[GRASS-dev] Interface description flag
Maris Nartiss maris.gis at gmail.com
Mon Nov 11 10:44:22 PST 2013
Hello Tyler,
it's a bit of "black magic" that has historical roots. General
documentation how it should work is here:
http://grass.osgeo.org/programming7/gislib_cmdline_parsing.html#gisprompt_Member
Hope it helps for a start.
Maris.
2013/10/31 Tyler Smith <tyler at plantarum.ca>:
> Hello,
> (sorry if this gets posted multiple times, I'm having email problems at my end)
> I'm developing an Emacs mode for interacting with the GRASS process,
> available here:
> https://bitbucket.org/tws/grass-mode.el/wiki/Home
> One of the features of this mode is offering tab-completion of command
> parameters. I use a lookup-table for this, populated by running all
> the programs in the bin/ directory with the -interface-description
> flag and parsing their output. This works fine for parameters that
> have a set list of possible values, like d.vect icon.
> However, I also have utility functions that provide completion of
> vector and raster map names. I don't understand the output of
> --interface-description well enough to know if there's a way to
> automatically identify parameters that should be completed with a
> vector name lookup. For example, all of the following combinations are
> completed by a vector map file:
> v.convert input= d.vect map= r.volume centroids= v.split input=
> I notice that each of them has the following item in their <parameter> tag:
> <gisprompt age="old" element="dig" prompt="vector" />
> The age and element values differ, but all four have prompt="vector".
> Can I use this to identify parameters that take a vector file name?
> That is, is the value of <gisprompt prompt="vector"> present for all
> commands that should be completed by a vector map name, and is this
> value absent from all other parameters?
> If not, is their another way to get this information directly from the programs?
> Thanks for your help,
> Tyler
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
