[GRASS-dev] modifying the dblink it require to re-build the topology
Moritz Lennert mlennert at club.worldonline.be
Tue Nov 12 12:42:13 PST 2013
On 12/11/13 20:37, Moritz Lennert wrote:
> On 09/11/13 17:23, Pietro Zambelli wrote:
>> On Thursday 07 Nov 2013 09:25:21 you wrote:
>>>> I'm doing something wrong or is it a bug?
>>> I thought that maybe you forgot to use the type parameter, but I
>>> just tried in the NC dataset and can confirm your issue.
>> ok, the bug should be fixed in r58179, at the end it was much easier
>> than I thought.
>> Please test the v.category module, to be sure that I've not introduced
>> new bugs. :-)
Sorry, forgot to mention. Haven't tested much but I haven't detected any
new problems.
Moritz
