[GRASS-dev] Using a multi-"${GIS_OPT_X}" input in a shell for loop
Hamish
hamish_b at yahoo.com
Wed Nov 13 01:06:15 PST 2013
Nikos wrote:
>> for Image in `echo $GIS_OPT_MSX | tr "," "\ "` ; do echo ${Image} ; done
Curly brackets do nothing to protect the contents of a variable. Using them
tricks new bash coders into thinking they are protected when they are not.
To avoid propagating the damaging myth, only use them when you actually need
them (eg to protect the variable name from following characters, not its contents).
Vaclav:
> Is GIS_OPT_MSX also in GRASS 7 (trunk)?
That's just going to be the contents of a msx= command line option defined in the
script header's #% definition.
regards,
Hamish
