[GRASS-dev] r58200 (attempt to fix failure when user name contains non-ascii characters)
    Glynn Clements
    glynn at gclements.plus.com
    Wed Nov 13 07:34:49 PST 2013
Martin Landa wrote:
> > What problem is it trying to fix?
> it fixes issue on Windows when user name contains non-ascii charecters
> (which is quite common on this platform).
> > And how does it do that (if it does actually work)?
> I have created on my Windows machine such user and this patch was
> necessary otherwise GRASS start script simply fails.
How/why does it fail? And how does this change fix that?
